[Qgis-user] deploy local repository
Alessandro Pasotti
apasotti at gmail.com
Fri Feb 3 07:15:11 PST 2017
we also have a collection of repository softwares here:
https://github.com/boundlessgeo/qgis-plugin-repos
from the most simple to the most complex one, pick up your favourite :)
static index.xml generator script:
https://github.com/boundlessgeo/qgis-plugin-repos/blob/master/cloud-foundry-static-repo/update_index.py
Cheers
On Fri, Feb 3, 2017 at 3:59 PM, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 03-02-17 11:24, Häfliger Guido wrote:
> > Hello
> > Is it possible to add a (local) plugin repository to all QGIS
> > installations in the network. I deploy QGIS via OSGeo4W-Installer with
> > packages on network drive. Where do I have to put the information about
> > additional plugin repos in the packages on the network drive? Or exist
> > a better solution to deploy our own plugins to the clients?
> Hi,
> You either create your own repo, by having a webdir, and adding some
> kind of these two files into it:
> https://github.com/rduivenvoorde/sectorplot/tree/master/repo
> then add the webpath to the plugins.xml as a url for a custom repo in
> the plugin manager.
> You have to change plugins.xml to have your own plugins off course.
> The xsl is only to have a nice 'html' view.
> Next to this two files you then can put your zips with your actual plugins.
> Another option would be to offer all your users the same plugins by
> copying them for them in there ~/.qgis2/python/plugins directory
> Hope this helps,
> Regards,
> Qgis-user mailing list
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170203/ac99b6ff/attachment.html>
