[Qgis-user] Possible bug QGIS 2.10
Luigi Pirelli
luipir at gmail.com
Wed Jul 12 01:21:09 PDT 2017
2.10.. is it outdated? do you know that LTR is 2.14 and current
version is 2.18.10?
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 12 July 2017 at 10:13, Lester Anderson <arctica1963 at gmail.com> wrote:
> Hello all,
> I am currently working with QGIS 2.10 and have just noticed a bug when
> creating and editing shapefiles. I know it's not the latest, but works
> fine for most jobs.
> If I make a shapefile, polygons or lines, it all looks fine in QGIS if
> I later go back and delete some objects in the file, but if I check in
> ArcMap then all the objects are still there. If QGIS shows 2 polygons
> ArcMap will show all, even those that were deleted.
> The only workaround I can see is to copy the polygons/lines into a new
> shapefile. It seems like the shapefile is not updating properly in the
> background even if it shows the correct elements in QGIS.
> It seems if you edit an existing shapefile in QGIS (2.10) that it
> still retains information on the objects that were deleted, although
> the attribute table does not show this. In ArcMap the attribute table
> shows all including deleted objects.
> Any ideas? Has this been corrected in later versions?
> Cheers
> Lester
> Qgis-user mailing list
