[Qgis-user] Possible bug QGIS 2.10
    Lester Anderson
    arctica1963 at gmail.com
    Wed Jul 12 01:53:48 PDT 2017
Found v2.12.3 and that showed the same behaviour.
Before I go ahead and get the latest version, can we confirm that the
bug is absent in the new versions?
Also can I confirm that this was a recognised bug.
Thanks
Lester
On 12 July 2017 at 09:21, Luigi Pirelli <luipir at gmail.com> wrote:
> 2.10.. is it outdated? do you know that LTR is 2.14 and current
> version is 2.18.10?
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> On 12 July 2017 at 10:13, Lester Anderson <arctica1963 at gmail.com> wrote:
>> Hello all,
>> I am currently working with QGIS 2.10 and have just noticed a bug when
>> creating and editing shapefiles. I know it's not the latest, but works
>> fine for most jobs.
>> If I make a shapefile, polygons or lines, it all looks fine in QGIS if
>> I later go back and delete some objects in the file, but if I check in
>> ArcMap then all the objects are still there. If QGIS shows 2 polygons
>> ArcMap will show all, even those that were deleted.
>> The only workaround I can see is to copy the polygons/lines into a new
>> shapefile. It seems like the shapefile is not updating properly in the
>> background even if it shows the correct elements in QGIS.
>> It seems if you edit an existing shapefile in QGIS (2.10) that it
>> still retains information on the objects that were deleted, although
>> the attribute table does not show this. In ArcMap the attribute table
>> shows all including deleted objects.
>> Any ideas? Has this been corrected in later versions?
>> Cheers
>> Lester
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
