[Qgis-user] Possible bug QGIS 2.10
Lester Anderson
arctica1963 at gmail.com
Wed Jul 12 02:30:19 PDT 2017
Thanks for the pointers. Think what I will do is download and test the
latest version at home before getting IT to install at work. The
software is great and does everything I need and more, plus easier to
work with compared to ArcMap (10.x)
Cheers guys
On 12 July 2017 at 10:24, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 12-07-17 10:53, Lester Anderson wrote:
>> Found v2.12.3 and that showed the same behaviour.
>> Before I go ahead and get the latest version, can we confirm that the
>> bug is absent in the new versions?
>> Also can I confirm that this was a recognised bug.
> Hi,
> Yes, it is recognised as a bug, but I cannot confirm if it was fully
> fixed. At the moment there is also discussion going on about how to
> handle this 'repacking'(?) of a shapefile when features are deleted. It is
> I would update anyway... and maybe try to leave shapefile as favourite
> data format, and move to for example geopackage (you probably need a
> newer QGIS for that too...)
> Regards,
> Richard
