[Qgis-user] Possible bug QGIS 2.10
Lester Anderson arctica1963 at gmail.com
Fri Jul 14 06:21:30 PDT 2017
Installed QGIS 2.18.10 - problem appears to be resolved
Cheers all
On 12 July 2017 at 10:30, Lester Anderson <arctica1963 at gmail.com> wrote:
> Thanks for the pointers. Think what I will do is download and test the
> latest version at home before getting IT to install at work. The
> software is great and does everything I need and more, plus easier to
> work with compared to ArcMap (10.x)
> Cheers guys
> On 12 July 2017 at 10:24, Richard Duivenvoorde <rdmailings at duif.net> wrote:
>> On 12-07-17 10:53, Lester Anderson wrote:
>>> Found v2.12.3 and that showed the same behaviour.
>>> Before I go ahead and get the latest version, can we confirm that the
>>> bug is absent in the new versions?
>>> Also can I confirm that this was a recognised bug.
>> Hi,
>> Yes, it is recognised as a bug, but I cannot confirm if it was fully
>> fixed. At the moment there is also discussion going on about how to
>> handle this 'repacking'(?) of a shapefile when features are deleted. It is
>> I would update anyway... and maybe try to leave shapefile as favourite
>> data format, and move to for example geopackage (you probably need a
>> newer QGIS for that too...)
>> Regards,
>> Richard
