[Qgis-user] Polar stereographic graticules in composer
Lester Anderson arctica1963 at gmail.com
Fri Jul 14 06:30:00 PDT 2017
Hello all
Just installed QGIS 2.18.10 and wanted to check the graticule plots in
Polar stereographic (projected units metres) using Long-Lat lines in
WGS-84 (Geographic degrees).
(1) At a scale of 1:10,000,000 the latitude lines show very obvious
straight line segments and not a continuous curve (smooth circle);
Longitude lines appear fine
(2) At a scale of 1:2,000,000 the latitude lines become smooth-looking
on the plot in composer.
At a regional scale (10M +) are the latitude lines supposed to look
crude when overlaying WGS84 (Geographic) graticules on Polar plots?
The behaviour is somewhat scale-dependent.
One could generate a vector grid and densify, but this defeats the
object of having the graticule option in composer. Just an
observation.
Thanks
Lester
