[Qgis-user] Looking for a function or variable to retrieve	canvas extent
    Alexandre Neto
    senhor.neto at gmail.com
    Wed Jun 21 09:05:01 PDT 2017
I guess those variables are simply not accessible from the attribute table
window. So there is no way you can use the map canvas for conditional
formatting.
DelazJ <delazj at gmail.com> escreveu no dia quarta, 21/06/2017 às 16:34:
> Thanks Alexandre, but it's too hot to have me doing some maths right now
> Actually, what I want to do is to apply some conditional formatting in the
> attribute table using the canvas extent values but for some reason, those
> variables you mentioned are not exposed in that expression builder dialog.
> There's also a @map_extent variable in master which returns the geometry
> (for composer map only? or canvas also?) but like others, it's not exposed.
> 2017-06-21 17:10 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
>> How about using the map_extent_center, map_extent_height and
>> map_extent_width to create a geometry?
>> DelazJ <delazj at gmail.com> escreveu no dia quarta, 21/06/2017 às 14:53:
>>> Hi,
>>> In the Expression dialog, is there a function or a variable that can
>>> return the current map canvas?
>>> I would like for example apply a value to all features that fall within
>>> the current map canvas but fail to find the right combination (if ever
>>> possible).
>>> Thanks for any hint,
>>> Harrissou
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170621/48066073/attachment.html>
