[Qgis-user] cross-layer attribute tables in composer
David Gessel
gessel at blackrosetech.com
Mon May 29 16:44:18 PDT 2017
Thank you! Exactly what I was looking for.
I'll have to mess with the SQL query to get the "Name" column in, but aggregating point data after specifying the geometry type worked.
-David
-------- Original Message --------
Subject: Re: [Qgis-user] cross-layer attribute tables in composer
To: David Gessel <gessel at blackrosetech.com>, qgis-user at lists.osgeo.org
Date: Tue May 30 2017 02:04:30 GMT+0300 (AST)
> Hi,
> You can create a virtual layer that "merges" all the necessary layers, and then add that layer attribute table to the map. Something similar to this:
> https://gis.stackexchange.com/a/215063/6191
> Best Regards,
> Alexandre Neto
> David Gessel <gessel at blackrosetech.com <mailto:gessel at blackrosetech.com>> escreveu no dia segunda, 29/05/2017 às 23:55:
> Is there a way to generate a single attribute table including data from multiple layers? Or, perhaps, another way to achieve the same goal:
> I have multiple layers of points. I'd like to include a table of attributes (in this case name, $x (latitude), $y (longitude)), but it isn't particularly efficient or pretty to add separate tables for each layer (there could be 15 or so in some maps).
> I thought maybe creating a "group" would allow me to source from that group, but no, that doesn't work.
> Any hints?
> -David
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
