[Qgis-user] QGIS to Blender - Converter / free global elevation mesh dataset
    Michael Nolde
    mnolde at gmx.net
    Fri Nov  3 06:56:12 PDT 2017
Hi Bernd,
Admittedly, geoTriMesh does get rather slow when using "larger" input
datasets. So you either might want to test with some lower resolution
data, or use the tiling-option, which seperates the input data into
smaller subsets.
For testing purposes, I included some sample files within the download,
you can find them in the plugin-directory
(\geoTriMeshQGIS\lib\geotrimesh\demodata). For a low resolution test
run, you can use, for example:
Bondaries: 'osm_2017_pottenstein_simple.shp'
DEM: 'gtopo30_1996_clip_pottenstein.tif'
Orthofoto: 'bmng_2004_clip_pottenstein.tif'
It should not take longer than a couple of seconds.
I totally agree that a little help file would be useful. I will see to
writing some more documentation in the near future.
Best regards,
Michael
Message: 3
Date: Sun, 29 Oct 2017 14:14:45 +0100
From: "Bernd Vogelgesang"<bernd.vogelgesang at gmx.de>
To:qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS to Blender - Converter / free global
Message-ID: <op.y8vgevewl2i25i at bernd-pc>
Content-Type: text/plain; charset=utf-8; format=flowed; delsp=yes
Hi Michael,
I installed the plugin an tried to test it.
So far I got no results. I tried it with a clip of a DEM of 10km radius of
the EUR_DEM Dataset.
Seems it does not want to finish, the log sais for a while {"percent":
99.93917274939103, "status_desc": "Calculating row 821 of 822"}
Maybe you could write some general recommendations about which sizes to
use, caveats etc (aka a "little" help file ;))
Cheers
Bernd
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171103/16740f42/attachment.html>
