[Qgis-user] QGIS to Blender - Converter / free global elevation mesh dataset
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Fri Nov 3 09:20:47 PDT 2017
Hi Michael,
besten Dank für die Infos.
Pottenstein ... bist Du aus der Gegend?
Grüße aus Baiersdorf
Bernd
Am 03.11.2017, 14:56 Uhr, schrieb Michael Nolde <mnolde at gmx.net>:
> Hi Bernd,
> Admittedly, geoTriMesh does get rather slow when using "larger" input
> datasets. So you either might want to test with some lower >resolution
> data, or use the tiling-option, which seperates the input data into
> smaller subsets.
> For testing purposes, I included some sample files within the download,
> you can find them in the plugin-directory
> (\geoTriMeshQGIS>\lib\geotrimesh\demodata). For a low resolution test
> run, you can use, for example:
> Bondaries: 'osm_2017_pottenstein_simple.shp'
> DEM: 'gtopo30_1996_clip_pottenstein.tif'
> Orthofoto: 'bmng_2004_clip_pottenstein.tif'
> It should not take longer than a couple of seconds.
> I totally agree that a little help file would be useful. I will see to
> writing some more documentation in the near future.
> Best regards,
> Michael
> Message: 3
> Date: Sun, 29 Oct 2017 14:14:45 +0100
> From: "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] QGIS to Blender - Converter / free global
> Message-ID: <op.y8vgevewl2i25i at bernd-pc>
> Content-Type: text/plain; charset=utf-8; format=flowed; delsp=yes
> Hi Michael,
> I installed the plugin an tried to test it.
> So far I got no results. I tried it with a clip of a DEM of 10km radius
> of the EUR_DEM Dataset.
> Seems it does not want to finish, the log sais for a while {"percent":
> 99.93917274939103, "status_desc": "Calculating row 821 of 822"}
> Maybe you could write some general recommendations about which sizes to
> use, caveats etc (aka a "little" help file ;))
> Cheers
> Bernd
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171103/edf07289/attachment.html>
