[Qgis-user] script filegdb to spatial lite
Matt Boyd
mattslists at gmail.com
Wed Nov 8 20:21:41 PST 2017
Thanks martin,
thats an excellent starting point for me. I'd already started digging into
ogr2ogr and the options you have there are good.
Does spatialite allow points, lines and polygon in the same database / file?
On Thu, Nov 9, 2017 at 3:11 PM, Martin Bain <Martin.Bain at lismore.nsw.gov.au>
wrote:
> Matt,
> Have a look into the ogr2ogr.exe which is installed with QGIS.
> It’s a command line program that converts formats. You could make a batch
> script to get the data you want one layer at a time into a single
> spatialite db. I’m afraid you got a bit of work to do to figure out the
> options for your input and output formats.
> Here’s a sample I found on my hard drive that I did some time ago to get
> data from a SQL Server table into Spatialite, to give you an idea of what’s
> involved. I don’t remember what all options are :P
> C:\OSGeo4W\bin\ogr2ogr.exe -f SQlite "C:\output7.sqlite"
> "MSSQL:server=xxxx;database=zzzz;trusted_connection=yes;" -sql "SELECT *
> FROM lOT" -a_srs "EPSG:28356" -dsco SPATIALITE=yes -nln "LOT" -nlt
> PROMOTE_TO_MULTI -geomfield SP_GEOMETRY –append
> Good luck.
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Matt Boyd
> *Sent:* Thursday, 9 November 2017 2:53 PM
> *To:* qgis-user <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] script filegdb to spatial lite
> Hi QGISers,
> I'm working from a corporate dataset, mostly geodatabases located on a
> network drive.
> I'd like to make a portable version of the datasets that I use that's
> updated either automaticaly, or whenever I run a script.
> I'm not 100% sure how spatialite works. Is everything in a single file
> database? I'd like to just create a script only grabbing the data I specify
> from the network drive and save that locally.
> I don't do the database updating so it's only a one way process.
> Has anyone done something like this? are there shortcuts?
> Thanks
> Matt
> This email is intended for the named recipient only. The information it
> contains may be confidential. If you are not the intended recipient you
> must not reproduce or distribute any part of this email, disclose its
> contents to any other party or take any action in reliance on it. If you
> have received this email in error, please contact the sender immediately
> and delete the message.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171109/31fbde99/attachment.html>
