[Qgis-user] QGIS SVG: outdated warning
Patrick Dunford
enzedrailmaps at gmail.com
Sat Nov 25 07:03:08 PST 2017
It looks a lot better in master than I used to remember from way back (I
started at 1.8). Maybe Qt have done some work on it.
On 26/11/17 01:07, Richard Duivenvoorde wrote:
> I added some layers, some blending and transparency, but to be honest
> both in 2.x and 3 outcomes (pdf and svg) were more or less ok to me....
> So not sure what it is exactly that I have to do to fail.
> The only difference is that in master I do not get the 'let's print in
> raster...' when printing a pdf.
> So what about: keeping the dialog (as I think at least for SVG the
> outcome will never be what a designer wants (id's, layers as layers etc
> etc), but change the message to: "Both pdf and svg exporting is done via
> the Qt-library. Results can vary based on complexity of (painting) of
> you map, but cannot be influenced by QGIS itself." or so?
> IF in future certain rendertasks appear to screw up either svg or pdf we
> can always add those?
