[Qgis-user] styling to cut out underlying features
Richard McDonnell
richard.mcdonnell at opw.ie
Thu Oct 5 03:28:39 PDT 2017
Ok, bear with me on this one!!
1. Go to Vector - Analyais Tools - Point in Polygon, using your point
file and polygon file as reference, create a new layer from this.
2. Once added you can then create a Join between your data and the new
one using only the PNTCNT Field
3. Then you can create a Virtual Field, and using an expression like
CASE WHEN "PNCNT" >0.5 THEN "Blank" WHEN "PNCNT" <0.5 THEN "Fill"
Your style should then be able to take care of the rest.
Ive not tested this, and I worry that the Virtual Field will stop
working once you remove the Join.
Hope it helps, or gives someone else an idea for an improved answer
Regards,
Richard.
On 04/10/2017 09:18, Fuenfer-Koenigstein.Benjamin2 at swm.de wrote:
> Hi all,
> I am looking for a way to style a point feature layer in a way that
> underlying features are cut out by the point symbols so a raster layer
> at the bottom of the layer tree is visible. In other words, the point
> symbol should make underlying vector features transparent. Physically
> editing the underlying features is not practicable as I’m working with
> read only data sources. I’m happy to hear your ideas!
> Mit freundlichen Grüßen
> Benjamin Fünfer-Königstein
> S-IP-AN-TG Techn. Geschäftsfelder
> Mobil: +49 (0)176 96 58 13 23
> Qgis-user mailing list
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171005/876e6147/attachment.html>
