[Qgis-user] Repeated maps with different datasets
Phil Wyatt
phil at wyatt-family.com
Thu Aug 30 20:29:44 PDT 2018
Hi ameces
Question - Are all the CSV the same data but just in a different municipaility?
One approach may be to merge all the csv into one, then do steps two and three, then create an 'atlas' output for each municipaility.
No special plugins required at all to do that
Cheers - Phil
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of ameces
Sent: Friday, 31 August 2018 9:43 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Repeated maps with different datasets
Hello,
I was wondering whether I could use some tool/plugin/additional software to
produce a big series of maps that are very similar to each other, except
that each one uses a different data set.
So in other words. I have a lot of different CSV-files that I input into
QGIS 2.18, and this is the process of me making a single map:
1) apply CSV-layer to QGIS, apply vector layer of the map of Finland and its
administrative borders (municipalities)
2) merge the CSV-data with the map vector layer, using municipality name as
the common value
3) create the classifications and visualize the data within the map
4) go into map layout mode and create a finished map with headlines, north
arrow, scale, legend etc.
5) and then do the same with a hundred different datasets
Is there a way to do this without going over every single step manually for
each map? I'm open to any solution, whether it was using QGIS, a different
version of QGIS, or even ArcGIS.
I have saved templates in the QGIS to save the map layout, but it doesn't
save a lot of time and it caused numerous crashes when I used it. For some
reason QGIS does not like when I save a map layout and then use it with
another map.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
