[Qgis-user] Repeated maps with different datasets
Phil Wyatt
phil at wyatt-family.com
Thu Aug 30 22:48:14 PDT 2018
Blimey!
That’s a lot of maps - 100 CSV X 3 values X 300+ municipalities = over 90,000 maps!
Can you point us to any of the data files?
Its beyond my skillset but I would be looking to use Processing and scripts to at least select a csv and then do all the joins and categorisation and place the data in layout and produce a map output. That’s if I couldn’t combine the CSV's in the first place to have a single record for each Municipality with the 300 values as columns.
Cheers - Phil
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of ameces
Sent: Friday, 31 August 2018 2:55 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Repeated maps with different datasets
Hi Phil!
I have a hundred different CSV files that have different numeric values for
the same municipalities. So for example I have one CSV that has values
1,2,3,4 on municipalities a, b, c and d.
Then another CSV that has 5,6,7,8 on the same municipalities a,b,c and d.
To be exact: all of my CSV's have only four columns. First is the name of
the municipality, then three columns of values that I want to make a map of
each one of them. So three maps from one CSV.
I hope I made some sense. :)
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
