[Qgis-user] Auth Manager
Alessandro Pasotti
apasotti at gmail.com
Mon Feb 5 10:06:11 PST 2018
On Mon, Feb 5, 2018 at 6:57 PM, Randal Hale <rjhale at northrivergeographic.com
> wrote:
> I'm not entirely sure I've titled this correctly.
> I have a client that has about 20 people editing. There is a want to
> reduce editing pain by introducing dropdown lists in the form of widgets.
> - 20 users have 20 logins to the postgres/postgis database
> - 20 users have 20 qgs files which need to be replaced
> My first thought to "fix" some of the headache was using the
> Authentification manager. I would have everyone set that up and I could
> build the qgs files and pass them along. They would open them and be asked
> for a password. The Authentification manager passes their credentials back
> to the database. It replaces the authcfg in the project with theirs and
> life is good.
> What I am finding is that my layers which have an Auth-id of xxxxxxx never
> get replaced by the Auth-id of their machine of yyyyyyyy - so every time
> they open my new qgs file they are prompted for the password of the authcfg
> database and their connection credentials. Which - maybe that's the way it
> works and not the way I think (which is generally not the way the world
> works).
> example: *dbname='client_database' host=gis4 port 5432 sslmode=disable
> authcfg=938s81lr key='id' srid=2274 type=multilinestring
> table="fiber.m_fiber" (geom) sql=*
> *Their authcfg is not** 938s81lr. **It never gets replaced with their
> authcfg*
> Is there a way to replace authcfg with their authcfg which would let me
> cascade these new QGIS files to the users? I could eliminate three things
> that must be typed down to one upon opening the file.
> Thanks much! Hopefully this all makes some sense.
> Randy
Hi, maybe I misunderstood your needs but I don't see the issue.
The authcfg is just an ID that the QGIS authentication manager uses to
retrieve the credentials from the QGIS user authentication DB.
If I get your point, what I suggest you is that you create your project
(the one that needs to be distributed) and configure your layers with a
custom authcfg (you can use up to 7 digits or letters to name it) and just
tell the users to create an entry in their authentication DB (using the
authentication manager in their QGIS instance) with same authcfg that you
have chosen and with their credentials.
Hope that helps!
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180205/d7c65740/attachment.html>
