[Qgis-user] Auth Manager
Randal Hale
rjhale at northrivergeographic.com
Mon Feb 5 11:02:12 PST 2018
Actually - that's excellent - it's working like I thought it should now!
Thanks - I had been looking at this way too long and ignoring the fact I
could make the authcfg whatever I wanted! So I was stuck on changing it
when I just needed to set it up differently.
Randy
On 02/05/2018 01:06 PM, Alessandro Pasotti wrote:
> On Mon, Feb 5, 2018 at 6:57 PM, Randal Hale
> <rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>> wrote:
> I'm not entirely sure I've titled this correctly.
> I have a client that has about 20 people editing. There is a want
> to reduce editing pain by introducing dropdown lists in the form
> of widgets.
> * 20 users have 20 logins to the postgres/postgis database
> * 20 users have 20 qgs files which need to be replaced
> My first thought to "fix" some of the headache was using the
> Authentification manager. I would have everyone set that up and I
> could build the qgs files and pass them along. They would open
> them and be asked for a password. The Authentification manager
> passes their credentials back to the database. It replaces the
> authcfg in the project with theirs and life is good.
> What I am finding is that my layers which have an Auth-id of
> xxxxxxx never get replaced by the Auth-id of their machine of
> yyyyyyyy - so every time they open my new qgs file they are
> prompted for the password of the authcfg database and their
> connection credentials. Which - maybe that's the way it works and
> not the way I think (which is generally not the way the world works).
> example: /dbname='client_database' host=gis4 port 5432
> sslmode=disable authcfg=*938s81lr* key='id' srid=2274
> type=multilinestring table="fiber.m_fiber" (geom) sql=/
> /Their authcfg is not/*/938s81lr. /*/It never gets replaced**with
> their *authcfg*/*/
> Is there a way to replace authcfg with their authcfg which would
> let me cascade these new QGIS files to the users? I could
> eliminate three things that must be typed down to one upon opening
> the file.
> Thanks much! Hopefully this all makes some sense.
> Randy
> Hi, maybe I misunderstood your needs but I don't see the issue.
> The authcfg is just an ID that the QGIS authentication manager uses to
> retrieve the credentials from the QGIS user authentication DB.
> If I get your point, what I suggest you is that you create your
> project (the one that needs to be distributed) and configure your
> layers with a custom authcfg (you can use up to 7 digits or letters to
> name it) and just tell the users to create an entry in their
> authentication DB (using the authentication manager in their QGIS
> instance) with same authcfg that you have chosen and with their
> credentials.
> Hope that helps!
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
Randal Hale
https://www.northrivergeographic.com
(423)653-3611
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180205/eaff31d3/attachment.html>
