[Qgis-user] Auth Manager
    Alessandro Pasotti
    apasotti at gmail.com
    Mon Feb  5 11:05:39 PST 2018
Glad it worked!
On Feb 5, 2018 20:02, "Randal Hale" <rjhale at northrivergeographic.com> wrote:
> Actually - that's excellent - it's working like I thought it should now!
> Thanks - I had been looking at this way too long and ignoring the fact I
> could make the authcfg whatever I wanted! So I was stuck on changing it
> when I just needed to set it up differently.
> Randy
> On 02/05/2018 01:06 PM, Alessandro Pasotti wrote:
> On Mon, Feb 5, 2018 at 6:57 PM, Randal Hale <rjhale at northrivergeographic.
> com> wrote:
>> I'm not entirely sure I've titled this correctly.
>> I have a client that has about 20 people editing. There is a want to
>> reduce editing pain by introducing dropdown lists in the form of widgets.
>>    - 20 users have 20 logins to the postgres/postgis database
>>    - 20 users have 20 qgs files which need to be replaced
>> My first thought to "fix" some of the headache was using the
>> Authentification manager. I would have everyone set that up and I could
>> build the qgs files and pass them along. They would open them and be asked
>> for a password. The Authentification manager passes their credentials back
>> to the database. It replaces the authcfg in the project with theirs and
>> life is good.
>> What I am finding is that my layers which have an Auth-id of xxxxxxx
>> never get replaced by the Auth-id of their machine of yyyyyyyy - so every
>> time they open my new qgs file they are prompted for the password of the
>> authcfg database and their connection credentials. Which - maybe that's the
>> way it works and not the way I think (which is generally not the way the
>> world works).
>> example: *dbname='client_database' host=gis4 port 5432 sslmode=disable
>> authcfg=938s81lr key='id' srid=2274 type=multilinestring
>> table="fiber.m_fiber" (geom) sql=*
>> *Their authcfg is not** 938s81lr. **It never gets replaced with their
>> authcfg*
>> Is there a way to replace authcfg with their authcfg which would let me
>> cascade these new QGIS files to the users? I could eliminate three things
>> that must be typed down to one upon opening the file.
>> Thanks much! Hopefully this all makes some sense.
>> Randy
> Hi, maybe I misunderstood your needs but I don't see the issue.
> The authcfg is just an ID that the QGIS authentication manager uses to
> retrieve the credentials from the QGIS user authentication DB.
> If I get your point, what I suggest you is that you create your project
> (the one that needs to be distributed) and configure your layers with a
> custom authcfg (you can use up to 7 digits or letters to name it) and just
> tell the users to create an entry in their authentication DB (using the
> authentication manager in their QGIS instance) with same authcfg that you
> have chosen and  with their credentials.
> Hope that helps!
> Alessandro Pasotti
> w3:   www.itopen.it
> Randal Hale rjhale at northrivergeographic.comhttps://www.northrivergeographic.com
> (423)653-3611
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180205/e70ad511/attachment.html>
