[Qgis-user] Unable to set the frame in the composer properly to	make the coordinates appear in QGIS 3.0.1
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Sat Jun  9 12:32:07 PDT 2018
Could it be a different CRS?  If you are expecting meters but the CRS is in degrees, you will have to zoom out a lot to see the one degree coordinates...
Just an idea
Nicolas
> Le 9 juin 2018 à 14:40, Pavlo Ro <pablocortesalcaide at gmail.com> a écrit :
> Dear everyone,
> I have had a problem regarding the frame in the composer. I cannot make the coordinates appear. I activate the frame, I check the box that says something like "visualise coordinates", and neither the inner, outer marks, the crosses, or the coordinates appear in the frame of the map (I'm using just one map in the composer, so there is no possible mistake regarding different maps views).
> I checked every possibility in the frame options, even trying very different values in the boxes which allow to change the values of the units (at least I think so), and I'm using WGS84 as CRS. This problem seems really odd to me, because I could manage to do that easily in QGIS 2.18.
> Could anyone guide me through this issue, or brainstorm some ideas about what could I be doing wrong?
> Thanks in advance!
> Qgis-user mailing list
