[Qgis-user] Irregular map frame with transparent mask?
Richard Duivenvoorde
rdmailings at duif.net
Wed Jun 20 04:40:30 PDT 2018
Ok, I fail on the grid labels around the province border...
But this is still not what you are looking for?
http://pix.toile-libre.org/upload/original/1529494583.png
I do not get your point is my feeling :-)
Richard
On 20-06-18 13:05, Alexandre Neto wrote:
> Thanks guys for your suggestions.
> Unfortunatly this was not what I was looking for. I was looking for a
> mask in the Layouts window. And I would like it to be full transparent
> regarding other elements of the layout.
> Following the example of the video, I would like to have a map item with
> the shape of that country. but I would like to see the layout items that
> are around the map.
> Cherry on top of the cake: that the grids still work fine with labels
> around the edges of the irregular shape.
> I hate cite ESRI but here it goes... Something like this image:
> https://community.esri.com/servlet/JiveServlet/showImage/2-753103-397442/pastedImage_2.png
> Thanks,
> Alex
> Richard Duivenvoorde <rdmailings at duif.net <mailto:rdmailings at duif.net>>
> escreveu no dia quarta, 20/06/2018 às 08:56:
> Works like a charm.
> Thanks Frank for the tip! Quick and easy:
> - copy a feature
> - paste as memory layer
> - put it on top
> - choose 'Inverted polygons' as Symbology
> - fiddle with transparency
> Is worth a blog post somewhere if you ask me :-)
> Regards,
> On 20-06-18 08:39, Frank Broniewski wrote:
> > The process in this video is really outdated, there’s an „inverted
> > polygon“ renderer which does the same without having to go through all
> > the hassle. You can find the renderer where you „select single
> symbol“,
> > „categorized“ etc.
> > HHT
> > Frank
> > Dipl. Geogr. Frank Broniewski
> > Waldhölzbacher Str. 51
> > 66679 Losheim am See
> > 06872 509 068 4
> > 0176 611 26 9 2 6
> > www.frankbroniewski.com <http://www.frankbroniewski.com>
> > *Von:*Qgis-user <qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>> *Im Auftrag von
> > *Phil Wyatt
> > *Gesendet:* Mittwoch, 20. Juni 2018 03:47
> > *An:* 'Alexandre Neto' <senhor.neto at gmail.com
> <mailto:senhor.neto at gmail.com>>; 'QGIS User'
> > <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>>
> > *Betreff:* Re: [Qgis-user] Irregular map frame with transparent mask?
> > Does this video show what you want to achieve?
> > https://www.youtube.com/watch?v=6h5kT2--xBM
> > Cheers - Phil
> > *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf
> > Of *Alexandre Neto
> > *Sent:* Wednesday, 20 June 2018 4:20 AM
> > *To:* QGIS User
> > *Subject:* [Qgis-user] Irregular map frame with transparent mask?
> > Hi,
> > I am looking for a way to create a map with an irregular
> (non-rectangle)
> > frame.
> > There is blog post from Anita showing how to do it but it needs a
> white
> > mask all around the map. While I need it to be transparent.
> > I don't think this is possible yet without going the SVGs way, but
> maybe
> > someone have so cool trick to share.
> > Thanks
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com
> > http://gisunchained.wordpress.com
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
