[Qgis-user] [QGIS-Developer] QGIS Processing "R" Provider -- 3.x beta available
Alex Mandel
tech_dev at wildintellect.com
Thu Nov 15 14:49:25 PST 2018
Nyall,
I can confirm the plugin loads without error on QGIS 3.4.1, Ubuntu 16.04
I'll need to find an R script or two to test with.
Thanks this is very appreciated,
Alex
On 11/15/18 14:34, Nyall Dawson wrote:
> Hi lists,
> Just a quick announcement that the Processing provider for R scripts
> in QGIS, which was dropped for QGIS 3.0, is now available as a beta
> for QGIS 3.4. It's now published as a standalone plugin which must be
> manually installed (together with manual installation of the
> underlying R software!).
> This is a pre-release beta version only -- the script syntax may
> change in the final release, so be warned that you may need to update
> scripts as a result. But the good news is that this should be 100%
> compatible with Processing R scripts from 2.x, with no change required
> to the scripts!
> To reflect its beta status, the plugin is currently only available via
> manual download from GitHub, and isn't (yet) available via the
> standard QGIS plugin repository. To install, download the zip release
> from https://github.com/north-road/qgis-processing-r/releases/tag/v0.0.2,
> and then install via the Plugins -> Manage and Install Plugins >
> Install from ZIP tab. After the plugin is installed you'll need to
> enable the provider via the Settings > Options > Processing >
> Providers > R > Activate checkbox.
> Testing feedback is sought and very welcome -- just file issues on
> https://github.com/north-road/qgis-processing-r/issues with a detailed
> description of any issues you encounter.
> This release was made possible thanks to a funding grant by QGIS.org.
> Regards,
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
