[Qgis-user] "Create Object from geometry" Feature
Raymond Nijssen r.nijssen at terglobo.nl
Fri Oct 12 00:07:40 PDT 2018
Hi Christian
On 12-10-18 08:53, Schmidt Christian wrote:
> Hello QGIS-community,
> We are quite new to working with PostGIS in QGIS 3.2.0, so we have some
> usability-questions…
> In the Autodesk world (don't hit me 😉) there is a feature called
> "create object from geometry".
> What it does, is to create a new database-object from an existing
> selected geometry. After creating the object
> you enter the attributes needed and commit it to the database.
> Is there any similar feature in QGIS? Is there any possibility to
> conviniently copy db-objects from table to table?
I think you can set that db layer to editable and then copy-paste
selected features from other layers to it. Attributes with the same
field name and type will be copied, others you can enter by manually
afterwards.
> We tried db-manager, but it was just good for importing/exporting data,
> though it's possible to import data from a temporary Qgis layer.
> But then we have problems with shortened attribute names in our
> temporary layers.
> So, is there any way to get/preserve long attribute-names in analysis?
> For ex. If we use "union" or
> "intersect" our input-attributes (from PostGIS) are shortened to
> shape-file-limit (10 characters?) thus it's quite time-consuming
> to get data back into the database.
Don't use shapefiles for this, that is where the fild name length limit
is. Try a memory layer instead. Or if you need to save is, try
geopackage (gpkg).
> Thx for your worthy hints, best regards from switzerland.
Good luck and regards from The Netherlands! :)
Raymond
> *Christian Schmidt
> *Stv. Geschäftsleiter**
> M.Sc. Photogrammetrie u. Geoinformatik
> *neuesReLISLogo*
> Bahnhofstrasse 40
> 5401 Baden
> Telefon: +41 56 210 39 60
> Mobile:  +41 78 684 70 09
> Email: C.Schmidt at relis.ch <mailto:C.Schmidt at relis.ch>
> Qgis-user mailing list
