[Qgis-user] topological editing don't works as expected
Antongeo76 antoviscomi at gmail.com
Thu Oct 18 02:49:46 PDT 2018
Saber Razmjooei wrote
> Could you maybe update the QEP with your opinion how exactly things should
> work?
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/69
> I will try to summarise the notes into bugs.
> Click-and-drag was decided not to be a good option for precise digitizing.
> So, unless you'd like that to be reverted, the rest can be addressed in
> bugs/feature request.
> Regards
> Saber
> On Thu, 18 Oct 2018 at 09:31, Antongeo76 <
> antoviscomi@
> > wrote:
>> DelazJ wrote
>> > Hi Régis,
>> > The issue priority is already set as high, tagged as a regression,
>> > mentioned (and argumented) in the QEP related to the vertex tool. We
>> are
>> > in
>> > bug fixing time. What is missing? An interested dev?
>> > IMO, the vertex tool refactoring brings nice features but having used
>> it
>> > more and more these last days, I find that we lose lot of handy
>> features
>> > and working with it in master is not that straightforward. And this has
>> > nothing to do with changing habits.
>> > I'm afraid that releasing 3.4 LTR with these issues (topology, vertex
>> > editor, adding simply a vertex on an existing segment...) would not
>> help
>> > people that do daily digitizing work. Just my opinion.
>> > Regards,
>> > Harrissou
>> > Le jeu. 18 oct. 2018 à 09:54, Régis Haubourg <
>> > regis.haubourg@
>> > > a
>> > écrit :
>> >> Well, we can raise its priority and call developpers that are funded
>> >> currently byt QGIS.org to work on it.
>> >> Régis
>> >> Le jeu. 18 oct. 2018 à 08:40, Alexandre Neto <
>> > senhor.neto@
>> > > a
>> >> écrit :
>> >>> Well, if there's a ticket already, there's not much more we can do.
>> >>> Unless someone is willing to sponsor that work/fix.
>> >>> Best regards,
>> >>> Alexandre Neto
>> >>> A qui, 18/10/2018, 05:57, Antongeo76 <
>> > antoviscomi@
>> > > escreveu:
>> >>>> Alexandre Neto wrote
>> >>>> > I can confirm that adding a new vertex to a polygon does not
>> create
>> >>>> > vertexes on other other polygons.
>> >>>> > You need to create a node on the other polygon, and then snap it
>> to
>> >>>> the
>> >>>> > first. Only then the topological node move work on both polygons.
>> >>>> > Not sure how it worked on 2.18, may be considered a regression.
>> >>>> > Alexandre Neto
>> >>>> > A qua, 17/10/2018, 10:30, Antongeo76 <
>> >>>> > antoviscomi@
>> >>>> > > escreveu:
>> >>>> >> Hi all,
>> >>>> >> in QGIS 3.2.3 as in MASTER
>> >>>> >> I need to edit a polygon shapefile with topological editing
>> active
>> >>>> >> -I set snap options with tolerance 1m to my layer
>> >>>> >> -I active topologica editing an spapping on intersection
>> >>>> >> -I try  to add a vertex on a polygon and move it for adjust
>> boundary
>> >>>> >> well
>> >>>> >> -the vertex is added only on one of two coincident polygon
>> boundary
>> >>>> >> -then when I try to move the added vertex this reshape only one
>> of
>> >>>> two
>> >>>> >> polygon...
>> >>>> >>       I expected that topological editing still works as in QGIS
>> 2,
>> >>>> >>       where when I add a vertex and move it the reshaping acts on
>> >>>> both
>> >>>> >> polygon who share the boundary I
>> >>>> >>       want to reshape
>> >>>> >> there is someone else that has noticed the same anomaly
>> >>>> >> Regards
>> >>>> >> Antonio
>> >>>> >> Antonio
>> >>>> >> Sent from:
>> >>>> http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> >>>> >> _______________________________________________
>> >>>> >> Qgis-user mailing list
>> >>>> > Qgis-user at .osgeo
>> >>>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >>>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >>>> > Alexandre Neto
>> >>>> > @AlexNetoGeo
>> >>>> > http://sigsemgrilhetas.wordpress.com
>> >>>> > http://gisunchained.wordpress.com
>> >>>> > Qgis-user at .osgeo
>> >>>> In 2.18 adding a vertex on a shared boundary,
>> >>>> This vertex becomes automatically shared too
>> >>>> There is a ticked on qgis issues
>> >>>> https://issues.qgis.org/issues/18046
>> >>>> Regards
>> >>>> Antonio
>> >>>> Sent from:
>> > Qgis-user at .osgeo
>> >>> Alexandre Neto
>> >>> @AlexNetoGeo
>> > Qgis-user at .osgeo
>> > Qgis-user at .osgeo
>> > Qgis-user at .osgeo
>> Hi DelazJ,
>> it is also my opinion it is extremely difficult to work for 8-10 hours
>> with
>> this new vertex editor,
>> in other words does not simplify our life, but requires much more
>> attention
>> and concentration.
>> In my opinion It's a shame because the vertex editor of QGIS 2 worked
>> very
>> well while the new one it is full of bugs and much less usable.
>> Antonio
>> Antonio
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user at .osgeo
> Saber Razmjooei
> www.lutraconsulting.co.uk
> +44 (0)7568 129733
> Qgis-user at .osgeo
Hi Saber;
I just left a comment on QEP
many thanks for your work
Regards
Antonio
