[Qgis-user] topological editing don't works as expected
    Saber Razmjooei
    saber.razmjooei at lutraconsulting.co.uk
    Thu Oct 18 01:35:48 PDT 2018
Could you maybe update the QEP with your opinion how exactly things should
work?
https://github.com/qgis/QGIS-Enhancement-Proposals/issues/69
I will try to summarise the notes into bugs.
Click-and-drag was decided not to be a good option for precise digitizing.
So, unless you'd like that to be reverted, the rest can be addressed in
bugs/feature request.
Regards
Saber
On Thu, 18 Oct 2018 at 09:31, Antongeo76 <antoviscomi at gmail.com> wrote:
> DelazJ wrote
> > Hi Régis,
> > The issue priority is already set as high, tagged as a regression,
> > mentioned (and argumented) in the QEP related to the vertex tool. We are
> > in
> > bug fixing time. What is missing? An interested dev?
> > IMO, the vertex tool refactoring brings nice features but having used it
> > more and more these last days, I find that we lose lot of handy features
> > and working with it in master is not that straightforward. And this has
> > nothing to do with changing habits.
> > I'm afraid that releasing 3.4 LTR with these issues (topology, vertex
> > editor, adding simply a vertex on an existing segment...) would not help
> > people that do daily digitizing work. Just my opinion.
> > Regards,
> > Harrissou
> > Le jeu. 18 oct. 2018 à 09:54, Régis Haubourg <
> > regis.haubourg@
> > > a
> > écrit :
> >> Well, we can raise its priority and call developpers that are funded
> >> currently byt QGIS.org to work on it.
> >> Régis
> >> Le jeu. 18 oct. 2018 à 08:40, Alexandre Neto <
> > senhor.neto@
> > > a
> >> écrit :
> >>> Well, if there's a ticket already, there's not much more we can do.
> >>> Unless someone is willing to sponsor that work/fix.
> >>> Best regards,
> >>> Alexandre Neto
> >>> A qui, 18/10/2018, 05:57, Antongeo76 <
> > antoviscomi@
> > > escreveu:
> >>>> Alexandre Neto wrote
> >>>> > I can confirm that adding a new vertex to a polygon does not create
> >>>> > vertexes on other other polygons.
> >>>> > You need to create a node on the other polygon, and then snap it to
> >>>> the
> >>>> > first. Only then the topological node move work on both polygons.
> >>>> > Not sure how it worked on 2.18, may be considered a regression.
> >>>> > Alexandre Neto
> >>>> > A qua, 17/10/2018, 10:30, Antongeo76 <
> >>>> > antoviscomi@
> >>>> > > escreveu:
> >>>> >> Hi all,
> >>>> >> in QGIS 3.2.3 as in MASTER
> >>>> >> I need to edit a polygon shapefile with topological editing active
> >>>> >> -I set snap options with tolerance 1m to my layer
> >>>> >> -I active topologica editing an spapping on intersection
> >>>> >> -I try  to add a vertex on a polygon and move it for adjust
> boundary
> >>>> >> well
> >>>> >> -the vertex is added only on one of two coincident polygon boundary
> >>>> >> -then when I try to move the added vertex this reshape only one of
> >>>> two
> >>>> >> polygon...
> >>>> >>       I expected that topological editing still works as in QGIS 2,
> >>>> >>       where when I add a vertex and move it the reshaping acts on
> >>>> both
> >>>> >> polygon who share the boundary I
> >>>> >>       want to reshape
> >>>> >> there is someone else that has noticed the same anomaly
> >>>> >> Regards
> >>>> >> Antonio
> >>>> >> Antonio
> >>>> >> Sent from:
> >>>> http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> >>>> >> _______________________________________________
> >>>> >> Qgis-user mailing list
> >>>> > Qgis-user at .osgeo
> >>>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>> > Alexandre Neto
> >>>> > @AlexNetoGeo
> >>>> > http://sigsemgrilhetas.wordpress.com
> >>>> > http://gisunchained.wordpress.com
> >>>> > Qgis-user at .osgeo
> >>>> In 2.18 adding a vertex on a shared boundary,
> >>>> This vertex becomes automatically shared too
> >>>> There is a ticked on qgis issues
> >>>> https://issues.qgis.org/issues/18046
> >>>> Regards
> >>>> Antonio
> >>>> Sent from:
> > Qgis-user at .osgeo
> >>> Alexandre Neto
> >>> @AlexNetoGeo
> > Qgis-user at .osgeo
> > Qgis-user at .osgeo
> > Qgis-user at .osgeo
> Hi DelazJ,
> it is also my opinion it is extremely difficult to work for 8-10 hours with
> this new vertex editor,
> in other words does not simplify our life, but requires much more attention
> and concentration.
> In my opinion It's a shame because the vertex editor of QGIS 2 worked very
> well while the new one it is full of bugs and much less usable.
> Antonio
> Antonio
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181018/c377a103/attachment-0001.html>
