[Qgis-user] QGIS Live GPS Tracking Settings (QGIS 2.14)
Phil Wyatt
phil at wyatt-family.com
Wed Oct 24 17:25:14 PDT 2018
Hi Malhar,
No, I don’t believe there are any ways to edit the GPS information as per your requests. If these features are a high priority for you then maybe consider supporting a developer to make some changes to the base code to allow changes to the GPS and the trail. I suspect Lat/Lon is the standard for most GPS’s but again a developer may be able to set options for other NMEA sentences.
Cheers - Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of malhar
Sent: Wednesday, 24 October 2018 11:26 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] QGIS Live GPS Tracking Settings (QGIS 2.14)
Hello all,
I am currently using the QGIS (2.14) live GPS tracker for a project. I have a few questions regarding the settings for the live tracking feature.
1) Is there a way to change the latitude and longitude units from decimal degrees to degrees and decimal minutes in the "GPS Information Panel?"
2) Is there a way to change the symbol of a cross within a circle to an airplane?
3) Is there a way to change the trail of the aircraft so it only shows the previous 10 minutes of flight, yet have the log file show the entire flight route?
Thank you very much for your help.
Sincerely,
Malhar
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181025/93bba6d2/attachment.html>
