[Qgis-user] Fwd: qgis - v.vol.rst from grass
Luigi Pirelli luipir at gmail.com
Mon Oct 29 01:12:28 PDT 2018
Hi Francois
is it just matter to create appropriate algorithm descriptop in qgis core?
e.g. doing a Pull Request (with tsts) to have the algoritym supported?
This guid sould give you the appropriate hints
https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass7/grass7.txt
and obviously all the descriptors available in:
https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/grass7/description
this is one of the QGIS part where users can help a lot adding new backend
algorithms with related tests. To create tests for a not tested algorithms
please see this guide:
http://www.opengis.ch/2016/02/04/increasing-the-stability-of-processing-algorithms/
a TODO list for grass is here:
https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass7/TODO.md
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Sun, 28 Oct 2018 at 16:01, Francois Chartier <fra.chartier at gmail.com>
wrote:
> Hi
> Is the plugin v vol rst available from within qgis?  i didnt see it in the
> list of vector plugin from grass.
> i am looking for a 3d interpolator and i believe only grass can do this in
> open source.
> Are there other plugins that can do 3d interpolation?
> by 3d i am not referring to interpolation of elevation, but by
> interpolation of 3d dataset with xyz + attribute (ex: soil moisture), with
> data points vertically stacked, and would need to interpolate verically and
> horizontally.
> thks
> f
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181029/e372476f/attachment.html>
