[Qgis-user] Unable to make qgis server work in QGIS 3.4.3
Reginald
Reginald.Carlier at ingelmunster.be
Wed Jan 16 00:11:45 PST 2019
Hello,
When I try to make a new project for qgis server in QGIS 3.4.3 I get
following error:
Opvragen kaart mislukt [Fout: Error transferring
http://localhost/cgi-bin/qgis_mapserv.fcgi.exe?MAP=Projecten/Zoneringsplan/vmm.qgz&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=63863.5,174278,78357.30000000000291,185638&CRS=EPSG:31370&WIDTH=120&HEIGHT=120&LAYERS=vmm&STYLES=&FORMAT=image/jpeg&DPI=120&MAP_RESOLUTION=120&FORMAT_OPTIONS=dpi:120
- server replied: Bad Request; URL:
http://localhost/cgi-bin/qgis_mapserv.fcgi.exe?MAP=Projecten/Zoneringsplan/vmm.qgz&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=63863.5,174278,78357.30000000000291,185638&CRS=EPSG:31370&WIDTH=120&HEIGHT=120&LAYERS=vmm&STYLES=&FORMAT=image/jpeg&DPI=120&MAP_RESOLUTION=120&FORMAT_OPTIONS=dpi:120]
Older projects made with a previous QGIS version still work as expected.
Has something changed in the way that webservices should be made?
I tried making a service with spatialite layers and with postgis layers but
no succes on QGIS 3.4.3.
How can I debug the service? When I use 'test configuration' everything is
fine.
Regards,
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
