[Qgis-user] prevrnt overlapping
st_kiefer at web.de
st_kiefer at web.de
Wed Jan 16 07:24:41 PST 2019
Hi Boaz,
this is kind of tricky, particularly, if the points in every single layer are not absolutly congruent.
a) if points are congruent (or if the offset of the points are euqal and in same direction in each layer), you might set an offset in the symbol-settings. You can set an offset for the simple marker. But if points are not congruent or randomly dispersed, this might lead to no nice results.
b) you combine all layers (you might distinguish them by an additional attribute if necessary) and use "Point displacement" in the symbols-settings.
c) you transform layers to shift points to distinct locations.
Hope that helps.
regards.
Stefan
> Boaz Bar Ilan <boazprosie at gmail.com> hat am 16. Januar 2019 um 08:16 geschrieben:
> hi
> im using 7 different layers with symbols on each and I want to prevent
> overlapping of the symbols
> what is the way ?
> thanks
> boaz
> Qgis-user mailing list
