[Qgis-user] Unable to make qgis server work in QGIS 3.4.3
Andreas Neumann a.neumann at carto.net
Wed Jan 16 00:19:28 PST 2019
Hi Reginald,
There is an issue (bug) in QGIS server 3.4.x  - that you cannot yet
request a top layer (I mean the one top layer coming from the project).
Instead you have to request a group or leaf layer.
A fix for that is coming soon - but perhaps you ran into this issue.
As to debugging: have you looked into the QGIS server log file? See
https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html#logging
- if you choose log level 0, you should get a lot of information - see
also
https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html#qgis-server-log-level
Greetings,
Andreas
Am 16.01.19 um 09:11 schrieb Reginald:
> Hello,
> When I try to make a new project for qgis server in QGIS 3.4.3 I get
> following error:
>   Opvragen kaart mislukt [Fout: Error transferring
> http://localhost/cgi-bin/qgis_mapserv.fcgi.exe?MAP=Projecten/Zoneringsplan/vmm.qgz&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=63863.5,174278,78357.30000000000291,185638&CRS=EPSG:31370&WIDTH=120&HEIGHT=120&LAYERS=vmm&STYLES=&FORMAT=image/jpeg&DPI=120&MAP_RESOLUTION=120&FORMAT_OPTIONS=dpi:120
> - server replied: Bad Request; URL:
> http://localhost/cgi-bin/qgis_mapserv.fcgi.exe?MAP=Projecten/Zoneringsplan/vmm.qgz&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=63863.5,174278,78357.30000000000291,185638&CRS=EPSG:31370&WIDTH=120&HEIGHT=120&LAYERS=vmm&STYLES=&FORMAT=image/jpeg&DPI=120&MAP_RESOLUTION=120&FORMAT_OPTIONS=dpi:120]
> Older projects made with a previous QGIS version still work as expected.
> Has something changed in the way that webservices should be made?
> I tried making a service with spatialite layers and with postgis layers but
> no succes on QGIS 3.4.3.
> How can I debug the service? When I use 'test configuration' everything is
> fine.
> Regards,
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
