[Qgis-user] Using SAGA Terrain Analysis - Hydrology
Anthony Greenish
agreenish at bluewin.ch
Mon Jan 21 08:58:32 PST 2019
Hello
I run into the following message "The following layers were not correctly
generated.<ul><li>C:/Users/Anthony/AppData/Local/Temp/processing_183557c8d1b
344aeaa17804e3e8d37dd/1bdc3ccd923b4634ad39d66b09203797/FILLED.sdat</li></ul>
You can check the 'Log Messages Panel' in QGIS main window to find more
information about the execution of the algorithm." When I try to run the
Fill sinks algorithm in Saga. I am running QGis 3.2.1 in Win 10. I've tried
to find the log/report in "QGis main window " but with no luck. Any help in
sorting out what the problem is would be very appreciated.
Thanks
greeton
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190121/49d260f5/attachment-0001.html>
