[Qgis-user] Using SAGA Terrain Analysis - Hydrology
Christophe Bayle
christophe at ecumene.fr
Mon Jan 21 09:12:17 PST 2019
Hi Anthony,
Got exactly the same problem few days ago trying to use these tools as well.
The only work around i found was to install an older version of QGIS.
(3.4.2 worked for a while, but then i got the same error.... so i finished
using 2.18)
Please let me know if you end up understanding the issue :)
All the best,
C.
On Mon, Jan 21, 2019 at 6:04 PM Anthony Greenish <agreenish at bluewin.ch>
wrote:
> Hello
> I run into the following message “The following layers were not correctly
> generated.<ul><li>C:/Users/Anthony/AppData/Local/Temp/processing_183557c8d1b344aeaa17804e3e8d37dd/1bdc3ccd923b4634ad39d66b09203797/FILLED.sdat</li></ul>You
> can check the 'Log Messages Panel' in QGIS main window to find more
> information about the execution of the algorithm.” When I try to run the
> Fill sinks algorithm in Saga. I am running QGis 3.2.1 in Win 10. I’ve tried
> to find the log/report in “QGis main window “ but with no luck. Any help in
> sorting out what the problem is would be very appreciated.
> Thanks
> greeton
> Qgis-user mailing list
Christophe Bayle
Ecumène Cartographie
Email: christophe at ecumene.fr
Tél: +33 6.64.91.64.85
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190121/59578f30/attachment.html>
