[Qgis-user] Clip Lines (Roads) with Polygon (States)
Mike Flannigan
mikeflan at att.net
Sun Mar 17 10:23:41 PDT 2019
Now I am wondering if I am posting to the correct list.
I guess it's not the list I intended to post to.
Anyway, when I filled this form out
http://www.mflan.com/temp/clip1.jpg
and clicked on "Run as Batch Process", it produces a
blank box:
http://www.mflan.com/temp/clip2.jpg
I didn't know what to do with that, so I did the same:
http://www.mflan.com/temp/clip3.jpg
but clicked on Run in Background, and it gave an error:
http://www.mflan.com/temp/clip4.jpg
But it did create a USAroads shape file. When I loaded it
it appeared to be blank, even though it is 10.9 MB:
http://www.mflan.com/temp/clip5.jpg
So I tried to find Feature (26).
I believe it is this one:
http://www.mflan.com/temp/clip6.jpg
If anybody has the patience for all of this, the
layer files are here:
http://www.mflan.com/temp/roads-north_america.zip
http://www.mflan.com/temp/statep010.zip
BTW, judging by other shape files I have found in my
records, I think I have successfully clipped roads in
the past. I just don't remember how to do it now.
Perhaps I need to create only one, single polygon for
the lower 48 states as a first step?? I will work on
that for now.
Mike
On 3/17/2019 9:34 AM, Mike Hyslop wrote:
> Good morning,
> In QGIS 3.x,
> Vector > Geoprocessing Tools > Clip
> Choose input and clip layer and output layer format and name.
> Intersect would add the attributes of both layers to the output; clip
> simply subsets the input features to the area encompassed by the clip
> (polygon) layer, which seems to be what you want.
> Best,
> Mike
> On Sun, Mar 17, 2019 at 10:03 AM Mike Flannigan <mikeflan at att.net
> <mailto:mikeflan at att.net>> wrote:
> Like so many others I would like to clip a roads
> layer to contain only roads within my polygon. Is
> this really the easiest way for me to accomplish that:
> https://api.queryxchange.com/q/23_212335/clip-or-intersect-lines-to-polygon-with-qgis/
> Yes, I see that there are a lot of possible ways
> to interpret "clipping a line with a polygon",
> but it seems like this should be easier than that.
> This is provided in case anybody can use these:
> http://www.mflan.com/temp/cliptest.qgs
> http://www.mflan.com/temp/cliptest.qgz
> Of course I don't just want it clipped, I want
> a simple clipping procedure that users like me
> can use.
> I am using QGIS 3.2 for Windows.
> Thank you.
> Mike
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190317/7ae92e22/attachment.html>
