[Qgis-user] QField: possible to add entry from relation?
Matthias Kuhn
matthias at opengis.ch
Tue Mar 19 00:01:41 PDT 2019
Hi Bernd,
Welcome on board!
It's not yet available but under heavy development in our R&D labs.
There are a couple of early development screenshots available at
https://github.com/opengisch/QField/pull/502 and even a alpha test app,
but it will still require some work before it's ready for prime time.
So for now, you will have to work with a plan B, but if you can wait a
month or two, you will be able to directly add your inspections via
nested forms.
Btw, there is a "fix me" link at the bottom of each page in the docs, if
you happen to find something that needs improvement, we'll be very happy
to have it fixed!
Best regards
Matthias
On 3/18/19 7:18 PM, Bernd Vogelgesang wrote:
> Hi,
> I'm going to try QField in the field for the first time, and, like
> always, I want to make it complicated ;)
> I have a point layer with over 500 nestingboxes in a huge area, and we
> are going to inspect and clean them.
> I created a Geopackage with this layer and also a non-spatial table
> where I would like to enter the results/actions which were taken on
> the boxes (value maps etc) and created a relation between those two
> layers via the box id.
> In QGIS itself, I can easily add a new entry in the non-spatial table
> via the form for the point layer.
> The same does not seem to work in QField, there I just see the
> attributes of the point layer and thats it.
> Is there a way to use relations in QField? It's not mentioned in the
> docs (https://www.qfield.org/docs/index.html) that it is not possible,
> but actually threre is not a lot mentioned anyway ;)
> Any ideas?
> Cheers,
> Bernd
> QGIS 3.6 on Linux Mint
> Qgis-user mailing list
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190319/907b11c1/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190319/907b11c1/attachment.png>
