[Qgis-user] QField: possible to add entry from relation?
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Tue Mar 19 00:24:47 PDT 2019
Hi Matthias,
actually I am already quite happy about what I managed to set up.
Found my final set-up at 3 a.m.. Especially the transferability of
styling of the layers (scale dependencies of labels, visibility etc) is
really great, but act a bit different than on the PC. Basemap rendering
is a bit slow..
I will have to enter the ID manually for now, which will definitely
produce some errors, but it is a first test.
So, now I'm on my way to my first QField-test in the field :) I will
definitely test more things and report back!
Thanks for all your efforts,
Bernd
Am 19.03.19 um 08:01 schrieb Matthias Kuhn:
> Hi Bernd,
> Welcome on board!
> It's not yet available but under heavy development in our R&D labs.
> There are a couple of early development screenshots available at
> https://github.com/opengisch/QField/pull/502 and even a alpha test
> app, but it will still require some work before it's ready for prime time.
> So for now, you will have to work with a plan B, but if you can wait a
> month or two, you will be able to directly add your inspections via
> nested forms.
> Btw, there is a "fix me" link at the bottom of each page in the docs,
> if you happen to find something that needs improvement, we'll be very
> happy to have it fixed!
> Best regards
> Matthias
> On 3/18/19 7:18 PM, Bernd Vogelgesang wrote:
>> Hi,
>> I'm going to try QField in the field for the first time, and, like
>> always, I want to make it complicated ;)
>> I have a point layer with over 500 nestingboxes in a huge area, and
>> we are going to inspect and clean them.
>> I created a Geopackage with this layer and also a non-spatial table
>> where I would like to enter the results/actions which were taken on
>> the boxes (value maps etc) and created a relation between those two
>> layers via the box id.
>> In QGIS itself, I can easily add a new entry in the non-spatial table
>> via the form for the point layer.
>> The same does not seem to work in QField, there I just see the
>> attributes of the point layer and thats it.
>> Is there a way to use relations in QField? It's not mentioned in the
>> docs (https://www.qfield.org/docs/index.html) that it is not
>> possible, but actually threre is not a lot mentioned anyway ;)
>> Any ideas?
>> Cheers,
>> Bernd
>> QGIS 3.6 on Linux Mint
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Matthias Kuhn
> matthias at opengis.ch <mailto:matthias at opengis.ch>
> +41 (0)76 435 67 63 <tel:+41764356763>
> OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190319/ee2b1df8/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190319/ee2b1df8/attachment-0001.png>
