[Qgis-user] export to dxf problem
Andreas Neumann
a.neumann at carto.net
Tue Nov 12 00:01:22 PST 2019
Hi Boaz,
The information you provide is unsufficient. You need to be more
specific.
Does Autocad issue an error message when you try to open the file? If
yes - what is the error message?
Have you tried other CAD software? There are plenty of them out there,
including free ones.
If you open the DXF file in a text editor, does it look like a complete
file or is it somehow truncated?
The fact, that the opening of the exported DXF file in QGIS again seems
to work, means that the file isn't totally broken.
Andreas
On 2019-11-12 08:33, Boaz Bar Ilan wrote:
> What happen is that when importing back the dxf file to the qgis it appear as x entities and appear with not the right crs and so i see nothing. And then in changing again the crs ( to what i saved it at the first place ) i see it fine.
> But the sane file on cad is aot seen .
> I hope thats cane clear
> Boaz
> בתאריך יום ג׳, 12 בנוב׳ 2019, 09:01, מאת Matthias Kuhn <matthias at opengis.ch>:
> Hi Boaz,
> what happens if you open the dxf in QGIS again?
> Matthias
> On 11/12/19 7:56 AM, Boaz Bar Ilan wrote:
> hi thanks
> somehow it doesn't work
> what I do - I select a layer and do - project >import export >export project to dxf
> there I save the scale to the scale on my qgis screen
> and when I m trying to view it with cad viewer it doesn't show nor on my partners autocad
> as much as I tried to pan it didn't work
> thanks
> boaz
> בתאריך יום ב׳, 11 בנוב׳ 2019 ב-22:35 מאת Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> AutoCAD programs have a tendency to open the file either zoomed out or zoomed away from our zone of interest. Ex. Your lines are in Canada but the files open in France. You need to find your data. Zoom in, zoom out or pan until you find it. Sometimes, you have a function saying « zoom to layer extent ». If that does not work, try to find your data looking at coordinates system.
> Don't forget to do a « reply all » so that the user groupe can profit from the conversation.
> Hope this helps
> Nicolas
> Le 11 nov. 2019 à 15:15, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> What you mean zooning on the data ?
> בתאריך יום ב׳, 11 בנוב׳ 2019, 21:20, מאת Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Hi,
> Try zooming on the data. It is quite possible that the data it there but that the file opens very far away from the data. That is a common problem with CADs.
> Nicolas
> On 2019-11-11 8:29 a.m., Boaz Bar Ilan wrote:
> thanks
> I did what you adviced
> succeeded reopen it in qgis
> but failed in the dxf viewer
> boaz
> בתאריך יום ב׳, 11 בנוב׳ 2019 ב-15:18 מאת Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Hi,
> You can only save a layer file to dxf, not a project file. Try selecting a layer file and saving that. Then reopen in QGIS before testing in other software. Share the layer file and the exact steps followed if that does not work.
> Nicolas
> Le 11 nov. 2019 à 08:07, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hallo
> im trying to export a project to a dxf
> as much as I try the file appear empty and nor I and nor other can open it
> I tried all the options
> where can I change something so that it will work ?
> thanks
> boaz _______________________________________________
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191112/906931c0/attachment.html>
