[Qgis-user] banging my head against the QGIS wall
    Jorge Gustavo Rocha
    jgr at geomaster.pt
    Fri Sep 13 12:25:52 PDT 2019
Hi Tom,
Às 19:49 de 13/09/19, Tom Vogt escreveu:
> Interesting idea. How can I call the WMS interactively ?
You can define environment variables and then call the executable on the
command. That is the best way to know what is going on.
Something like (this is for Linux, but Windows should be similar):
export QUERY_STRING="SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities"
export QGIS_PROJECT_FILE="/home/jgr/qgis/ne_10m_admin_0_countries/world.qgz"
/usr/lib/cgi-bin/qgis_mapserv.fcgi
> There is, to be honest, not enough documentation on the QGIS server. I
> still don’t understand how it picks a map file when you don’t give one
> explicitly, for example.
You can pass the MAP parameters or use the project defined in the
configuration. So, if you don't use a MAP parameter, it will use the
project defined in your *.conf file.
Best regards,
Jorge Gustavo
>> Am 13.09.2019 um 20:39 schrieb Alessandro Pasotti <apasotti at gmail.com
>> <mailto:apasotti at gmail.com>>:
>> You can try with python, and call it interactively. Also increase the
>> logging level and if you can access a debug build set QGIS debug on.
>> Last resource you can use a real debugger, check this out:
>>  https://github.com/elpaso/qgis-dev-vagrant
>> On Fri, Sep 13, 2019, 20:28 Tom Vogt <tom at lemuria.org
>> <mailto:tom at lemuria.org>> wrote:
>>     Hey everyone,
>>     I’ve been playing with QGIS for many years, but now I’m on the
>>     mailing list as well. I’ve been banging my head against QGIS for
>>     the past two days and just can’t get it to work, so maybe I can
>>     find help here. It just doesn’t give me WMS tiles or they are
>>     blank. Then I fiddle around and it works, then I clean it up to
>>     make it work and it stops again. It’s driving me crazy. :-)
>>     Any hints on debugging qgis_mapserv.fcgi ?
>>     Tom
>>     _______________________________________________
>>     Qgis-user mailing list
>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Logo*   Geomaster, LDA*
  *VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC**O
Avenida Barros e Soares
N.º 423, 4715-214 Braga
VAT/NIF510 906 109
Phone  +351 253 680 323
Site       geomaster.pt <http://geomaster.pt>
GPS       41.53322, -8.41929
Jorge Gustavo Rocha
CTO
Mobile  +351 910 333 888
Email    jgr at geomaster.pt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190913/28f732de/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190913/28f732de/attachment-0001.png>
