[Qgis-user] GeoPackage deadlocks
Andrea Peri
aperi2007 at gmail.com
Thu Sep 26 02:10:45 PDT 2019
Geopackage is an Exchange format. Is not affordable in a multiuser data
entry environment.
This require a dbms like postgres + postfis.
Regards,
Andrea.
Il gio 26 set 2019, 10:18 Enrico Fiore <enricofiore at libero.it> ha scritto:
> Hi,
> Is anyone else getting occasional deadlocks when using GeoPackages in the
> Long Term Release of QGIS?
> We are using them over a Windows network so there are multiple users
> trying to access the same GeoPackage files. It all seems fine and two or
> more can open the file to look at but when someone edits it you sometimes
> hit a deadlock where none of the QGIS applications will shut down.
> I have the same issue and the same scenario. Multiple users that trying to
> access a the same GeoPackage file located in a server causes QGIS deadlock.
> The issue rises also if no geopackage layer are in editing mode, but
> simply loaded in one QGIS view.
> There is a solution for this behaviour or is this a bug?
> Regards,
> Enrico
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190926/10ada3cf/attachment.html>
