[Qgis-user] Layer disappearing at different zoom levels.
Richard Duivenvoorde rdmailings at duif.net
Sun Apr 5 23:53:58 PDT 2020
Mmm, no I see you are taking about ArcGis layers... not sure if my
epistel below is still valid. Sending anyway...
In my experience the heuristic (if there is) to determine to set the
right crs in QGIS for WMS is not optimal.
Sometimes if a WMS-layer is first, the project takes that layer too so
all is ok.
But sometimes when a project crs is already set, a WMS seems to set a
default crs, OTHER then the project crs and the layer is requested in
another crs then the crs of the project, giving weird results. Maybe if
the WMS advertizes a preferred CRS or so (is this possible)?
Especially the browser is not very clever in this.
So my advice: if the browser works, do it, but if you (as I think) have
a project and are requesting WMS layers in different CRS's then it is
better to use the WMS-dialog.
Then be sure that ALL your wms layer AND your project layer are
requested in the right (or that least the same) crs.
Hope This Helps, Regards,
On 4/6/20 5:36 AM, krishna Ayyala wrote:
> QGIS Desktop 3.12.0
> On Sun, Apr 5, 2020 at 9:13 PM Nyall Dawson <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
>     On Mon, 6 Apr 2020 at 13:08, krishna Ayyala <ayyalakrishna at gmail.com
>     <mailto:ayyalakrishna at gmail.com>> wrote:
>     > Hello,
>     > Using the "ArcGisMapServer" in the browser window, I have
>     connected to the following link.
>     > https://hazards.fema.gov/gis/nfhl/rest/services/public/NFHL/MapServer
>     > I have added  the "Alluvial Fans" and "FIRM Panels" in to layers
>     window. Map and both the layers are set to the projection EPSG:4269.
>     Righ clicked on  "Alluvial Fans" and zoom to layer. I am able to see
>     both the layers on the map window. Right clicked on  "FIRM Panels"
>     and zoom to layer. Unable to see anything in the map window. Can
>     anyone please help me fix this problem?
>     Which QGIS version are you using?
>     Nyall
>     > Regards.
>     > _______________________________________________
>     > Qgis-user mailing list
>     > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
