[Qgis-user] Sharing project files
Michael Dufty MDufty at mbsenvironmental.com.au
Mon Apr 6 18:17:03 PDT 2020
I find the “Memory Layer Saver” plugin very useful, but it doesn’t seem to work for raster layers, so may not work for Dave in this case.
If I recall correctly I think the make permanent button may not appear on raster layers either.
Generating contours to a temporary file also seems to be a special case in that they save to a temporary file rather than a memory layer so neither of the above options work.
In these cases you need to “save as” the temporary layers to preserve them (or create them as permanent layers in the first place using the processing options).
Michael Dufty
Senior Environmental Engineer
[cid:image001.jpg at 01D60CBC.8E1516A0]
MBS ENVIRONMENTAL
4 Cook Street, West Perth  WA 6005
t:    +61 8 9226-3166
f:    +61 8 9226-3177
e:   mdufty at mbsenvironmental.com.au<mailto:mdufty at mbsenvironmental.com.au>
w:   www.mbsenvironmental.com.au<blocked::http://www.mbsenvironmental.com.au/>
Disclaimer:
The information contained in this message is intended for those to whom it is addressed. It may contain confidential or privileged information and if you are not the intended recipient, you must not copy, distribute or take any action in reliance on it. If you received this message in error please destroy it and reply to the sender immediately or contact Martinick Bosch Sell Pty Ltd. on +61 8 9226 3166 immediately. All care has been taken to ensure that this message and any attachments are virus free; we do not accept responsibility for any virus infections caused by receipt of this message
From: Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
Sent: Tuesday, 7 April 2020 1:10 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Sharing project files
Hi Dave,
indeed, temporary layers are only .. well .. temporary.
There are two ways to make them permanent (afaik):
a) Install the temporary layer saver plugin. This will save those layers within the project file
b) Don't know if this option already exists in 3.4, but in the context menu of a temporary layer, there should be the option "Make permanent ...", so you can save it to disk. If it is not present in 3.4, update to 3.10 LTR or to the latest 3.12
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200407/8dfacac9/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200407/8dfacac9/attachment.jpg>
