[Qgis-user] ISSUE QGIS keeps freezing - QGIS Desktop 3.10.4
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Thu Apr 9 01:15:55 PDT 2020
Hi Koos:
That's not much information to go on.
What about: OS type and version ? 32/64 bit os ? QGIS version ? QGIS
32/64 bit ? network environment ? Normal stand-alone installation or
Network installation ?
I'll hazard a *guess* based on my own painful experiences: You are
working in a networked windows setup, where your IT department has made
some modifications for home directory (including temp file placement)
and/or the userdata environment - maybe making it fully dependant on the
network. And maybe You are using the same login account for all pupils.
Combine this with a marginally functioning network and it will be a
train wreck
Another scenario: You have installed some plugin, that's not working
correctly.
What you can test:
* Disable/Remove all plugins from QGIS and test if the problem goes away
* Load some GIS data locally on you computer and disconnect the
computer from the network. Then test QGIS again.
That said, QGIS ver. 3.10 onwards has long startup times. However it's
quick and stable after that
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 09-04-2020 kl. 09:46 skrev Koos Fransen:
> Dear all
> I have a question regarding QGIS.
> I’m using QGIS for my classes, but since a recent install my QGIS
> keeps freezing right after startup. It doesn’t respond until after a
> minute, then I can open some files and then it freezes again. This
> keeps on going, making it impossible to keep working with QGIS.
> I’ve tried reinstalling, which always helps at first, but after a
> couple of days it starts freezing again. I’ve also tried with
> different versions, with the same result.
> It might maybe have something to do with temporary files?
> Has someone experienced the same issue, and are there possible
> solutions that you know of?
> Thanks!
> Koos
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200409/610aa080/attachment.html>
