[Qgis-user] tracing
Andreas Neumann a.neumann at carto.net
Mon Aug 10 22:57:52 PDT 2020
Hi Jake,
No - it shouldn't be necessary to recreate your project. It is probably
just a setting.
Can you snap to the vertices of the vector layer you want to trace
along? If not, can you at least select features in the layer you want to
trace along?
There are a number of settings that could prevent snapping and tracing:
- in the project settings you could have set a layer to not being able
to select
- the snap settings might have strange settings (map units, bad
distances).
Can you share the snap settings of the layer you want to trace along (a
screenshot of the digitizing toolbar or advanced snapping dock?)
But once you can snap, then you should also be able to trace.
Andreas
On 2020-08-11 02:02, j.m at jmforestry.com wrote:
> Thank you, Andreas and Alexandre.
> I tried with a vector layer on another project and it worked. Is there a way now to fix the "broken project, or will I have to recreate it from scratch? Do you have an idea why that would happen?
> Thanks again for your help
> Jake
> From: Andreas Neumann
> Sent: Sunday, August 09, 2020 15:21
> To: j.m at jmforestry.com
> Subject: Re: [Qgis-user] tracing
> Hi Jake,
> Are you trying to trace along other existing vector features (built-in QGIS functionality) or based on a raster layer with the tracing plugin?
> For the former: you might have disabled the snapping options for the layers you want to trace along, or simply have disabled tracing. Have you checked the snapping toolbar and more specifically the tracing button? It might also be the case, that the snapping-tolerances do not work, e.g. when you have set them to map units with a bad scale combo - instead of pixel values.
> Greetings,
> Andreas
> Am 09.08.20 um 16:30 schrieb j.m at jmforestry.com:
>> I got the tracing function to work one time but not anymore. I do not know what I did differently, but the program will not trace anymore. I also have problems all of a sudden to use topological editing.
>> What do I overlook.
>> It happened with 3.12 and now I installed 3.14 and it's still the same.
>> I have a windows computer and try to run the latest updates.
>> Thank you all for this incredible support service you maintain with QGIS.
>> Jake
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200811/f8d4374c/attachment.html>
