[Qgis-user] Python Plugin error "Host not found"
Richard Duivenvoorde
rdmailings at duif.net
Mon Aug 17 04:16:21 PDT 2020
On 8/17/20 11:04 AM, Sarah Way wrote:
> Hello,
> I am a relatively new user and thus still learning as I go...
> Can anyone please help me fix a Python plugin repository error?
> I was running QGIS 3.4.13 and trying to select the XYTools plugin when I received the QGIS Python Plugin Installer error window:
> "Error reading repository: QGIS Plugin Repository: Host not found"
> When I went into the Plugin settings, I noticed that the QGIS Official Plugin Repository was showing the green connected status, but the QGIS Plugin Repository was saying red disconnected.
> I upgraded to QGIS 3.10.7 to try and address the issue, however I received the same message.
Hi Sarah,
There is just one plugin repository, so can you have a look and show us which url's you have?
You should only have:
https://plugins.qgis.org/plugins/plugins.xml
(and QGIS will append "?qgis=3.4" for you)
If you have others, please remove those.
You can always create a new 'profile' and see if that one works.
Regards,
