[Qgis-user] Loading up .grd files into QGIS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Aug 28 14:22:52 PDT 2020
oops here is the correct link to the GXF driver page:
https://gdal.org/drivers/raster/gxf.html
Happy #KwakFriday !
-jeff
On 2020-08-28 6:21 p.m., Jeff McKenna wrote:
> Hi Alan,
> Since you now have a .gxf file, here are my testing steps that I just
> performed locally:
> QGIS relies on the GDAL library for raster/vector access. When hitting
> a new format and wondering if QGIS can read it, always start by going to
> https://gdal.org and scroll down the page and look for your format: for
> example, you will see "GXF" listed there under raster drivers:
> http://download.osgeo.org/gdal/data/gxf/ Give that a read as a start
> always (put another way: *always* start by reading the GDAL driver page
> for your format, read the entire driver page as it usually contains
> important information).
> From reading that, now you know that the GXF driver is always built by
> default, so that means you should be able to use QGIS to read your QXF
> file.
> (if you prefer the commandline, executing 'gdalinfo --formats' on your
> local machine should return the GXF driver in the long response, and
> then you can try 'gdalinfo myfile.gxf' )
> You can actually use GDAL test data to verify this: download
> "sample.gxf" from http://download.osgeo.org/gdal/data/gxf/
> Open "sample.gxf" in QGIS ("Add Raster Layer") and it should look like:
> https://pasteboard.co/JovJFDMF.png
> Hope these steps help! cheers from the east coast of Canada,
> -jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
