[Qgis-user] error loading tiff layer
Humberto Nel Florez Ramos hnflorezramos at gmail.com
Mon Feb 3 03:11:35 PST 2020
 Thanks for the reply, but the file has all the information necessary to be
loaded correctly.
The file comes from arcgis, I have tried to load it with gvsig 2.5, SNAP
desktop 6.0 and everything seems to indicate that they are not able to read
the projection information correctly.
i keep trying
El vie., 31 ene. 2020 a las 8:01, kirk (<kirk at nortekresources.com>)
escribió:
> The file may not be a geotiff and therefore require a seco d file in the
> directory in which it resides. A .twf or .aux file with the same name as
> your tiff file.
> Sent from my Samsung Galaxy smartphone.
> -------- Original message --------
> From: Humberto Nel Florez Ramos <hnflorezramos at gmail.com>
> Date: 2020-01-31 7:10 AM (GMT-04:00)
> To: Qgis-user at lists.osgeo.org
> Subject: [Qgis-user] error loading tiff layer
> regards.
> I could not load a layer in tiff format. The error that qgis shows is:
> "No transform is available between Unknown CRS: ENGCRS [" PCS Name =
> unnamed ", EDATUM [" "], CS [Cartesia ... and Unknown CRS: GEOGCRS ["
> unknown ", DATUM [" unknown ", ELLIPSOID [" WGS 8 ... .
> No coordinate operations are available between these two reference systems
> The file has a reference system, which is magna-sirgas from Bogota (3116),
> I have tried the magna-sirgas (3116) project, and wgs84 (4326) showing the
> same error.
> The version of qgis is 3.10.2-A CoruƱa.
> thank you very much for the help and I remain attentive
> [image: imagen.png]
> Humberto NFR
Humberto NFR
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200203/869661a9/attachment.html>
