[Qgis-user] error loading tiff layer
Richard McDonnell
richard.mcdonnell at opw.ie
Mon Feb 3 04:12:05 PST 2020
You can gave a raster using the correct coordinates (extents) but not with the CRS assigned.
Could I suggest you utilise gdal_edit ( https://gdal.org/programs/gdal_edit.html ) and assign the CRS EPSG:3116 to the raster and try again?
You can perform this within QGIS using the Processing tools just search for “edit” and select Assign Projection just select the valid CRS from the list and run it.
Hope this helps,
Regards,
Richard.
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 1 647 6543
https://www.opw.ie
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.opw.ie/en/disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Humberto Nel Florez Ramos
Sent: 03 February 2020 11:12
To: kirk <kirk at nortekresources.com>
Cc: Qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] error loading tiff layer
Thanks for the reply, but the file has all the information necessary to be loaded correctly.
The file comes from arcgis, I have tried to load it with gvsig 2.5, SNAP desktop 6.0 and everything seems to indicate that they are not able to read the projection information correctly.
i keep trying
El vie., 31 ene. 2020 a las 8:01, kirk (<kirk at nortekresources.com<mailto:kirk at nortekresources.com>>) escribió:
The file may not be a geotiff and therefore require a seco d file in the directory in which it resides. A .twf or .aux file with the same name as your tiff file.
Sent from my Samsung Galaxy smartphone.
-------- Original message --------
From: Humberto Nel Florez Ramos <hnflorezramos at gmail.com<mailto:hnflorezramos at gmail.com>>
Date: 2020-01-31 7:10 AM (GMT-04:00)
To: Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
Subject: [Qgis-user] error loading tiff layer
regards.
I could not load a layer in tiff format. The error that qgis shows is:
"No transform is available between Unknown CRS: ENGCRS [" PCS Name = unnamed ", EDATUM [" "], CS [Cartesia ... and Unknown CRS: GEOGCRS [" unknown ", DATUM [" unknown ", ELLIPSOID [" WGS 8 ... .
No coordinate operations are available between these two reference systems ".
The file has a reference system, which is magna-sirgas from Bogota (3116), I have tried the magna-sirgas (3116) project, and wgs84 (4326) showing the same error.
The version of qgis is 3.10.2-A Coruña.
thank you very much for the help and I remain attentive
Humberto NFR
Humberto NFR
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200203/013d9ce2/attachment.html>
