[Qgis-user] QGIS uninstalled after GDAL PPA install
Jürgen E. Fischer
jef at norbit.de
Fri Feb 28 12:27:08 PST 2020
Hi Jimi,
On Fri, 28. Feb 2020 at 18:29:26 +0100, J. M wrote:
> I'm still not clear about what the ubuntugis PPA is needed for, or what
> gdal even is..
GDAL is what is being used to access raster and vector files.
ubuntugis provides more uptodate packages including GDAL and PRØJ. So to use
those we normally have also qgis builds based on ubuntugis in
https://qgis.org/ubuntugis next to those for the plain ubuntu release in
https://qgis.org/ubuntu. The former also requires adding the ubuntugis
unstable repository.
Currently we can work with GDAL2 from plain ubuntu and although we could work
with GDAL3, we cannot use GDAL 3 from ubuntugis, because we also require PRØJ
6.3.1 and ubuntugis only provides 6.2.1.
So there are no current builds for ubuntugis and therefore for bionic you
should remove all the packages you installed from https://qgis.org/ubuntugis or
the ubuntugis repo and install from https://qgis.org/ubuntu instead.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200228/dbd3cbdf/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200228/dbd3cbdf/attachment.ksh>
