[Qgis-user] Where to store style files (qml, sld) - best practices
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sun Jul 19 05:40:31 PDT 2020
I think he refers more to where to store style templates etc. At least
for me, I never managed to build something meaningful, and although I
always need the same kind of styles, I redo them evertime instead of
creating good templates for my use cases. The user directory which is
set by default is kind of vulnerable when removing old qgis versions or
doing other stupid stuff. An extra directory for such templates
(styles, models, etc) is on my list ...
So, for the time beeing, my super-sophistcated styles just sit within my
project files, and I have to guess where I used which fancy trick to
achive something special.
Cheers,
Bernd
On 19.07.20 14:25, Jose Gomez wrote:
> Hi, It's better in the same directory where you have the data and you
> should use the same name. If you work with shapefile, when you add the
> layer it recognizes the style and assigns it symbology. If you use
> geopackage could be better save it in the database (geopackage), for
> use the simbology when you add the layer.
> Regards,
> José Luis Gómez Díaz
> Ing. Catastral y Geodesta, Esp, Magister
> El sáb., 18 de jul. de 2020 a la(s) 22:41, <qgis-user at stripfamily.net
> <mailto:qgis-user at stripfamily.net>> escribió:
> Is there a convention on where to place these files? Perhaps a new
> directory in the profile?
> It appears they can be saved anywhere, but I'm curious about best
> practices conventions?
> Create the file in a tmp location and import into the style manager?
> So many choices.
> Thx
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Saludos,
> José Luis.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200719/fb6c7b29/attachment.html>
