[Qgis-user] How to install QGIS in Debian 11?
Todd Pfaff
pfaff at rhpcs.mcmaster.ca
Thu Jul 23 06:26:07 PDT 2020
On Wed, 22 Jul 2020, Richard Duivenvoorde wrote:
> - learn about 'flatpak' and use that to run 3.14
> (https://qgis.org/en/site/forusers/alldownloads.html#flatpak). Though
> flatpak has some limitations as it runs in a sandbox...
Are those limitations and how they impact the capabilities of QGIS
documented anywhere? I don't see anything about limitations here:
https://www.qgis.org/en/site/forusers/alldownloads.html#flatpak
nor here:
https://flathub.org/apps/details/org.qgis.qgis
I believe I've run into a big limitation. I've installed flatpak QGIS
on a CentOS 7 linux system. When I try to run it I get this error:
$ flatpak run org.qgis.qgis
QGIS starting in non-interactive mode not supported.
You are seeing this message most likely because you have no DISPLAY
environment variable set.
Any ideas about what limitation is causing that error?
Thanks!
