[Qgis-user] How to install QGIS in Debian 11?
Richard Duivenvoorde
rdmailings at duif.net
Thu Jul 23 06:40:41 PDT 2020
On 7/23/20 3:26 PM, Todd Pfaff wrote:
> I believe I've run into a big limitation. I've installed flatpak QGIS on a CentOS 7 linux system. When I try to run it I get this error:
> $ flatpak run org.qgis.qgis
> QGIS starting in non-interactive mode not supported.
> You are seeing this message most likely because you have no DISPLAY
> environment variable set.
> Any ideas about what limitation is causing that error?
Mmm, this is not so much QGIS related (I guess...), are you able to run any other GUI programs running flatpak?
This looks more like you are maybe trying to run over een X-remote connection?
Or your flatpak install is weird?
I googled some things:
https://github.com/flatpak/flatpak/issues/397
or:
https://docs.flatpak.org/en/latest/sandbox-permissions.html
HTH
Regards,
