[Qgis-user] FW: Help with georeferencing AGD66 Topo map
Thayer Young
thayeray at yahoo.com
Sat May 2 07:45:17 PDT 2020
A similar question was asked on this list not so long ago. You may want to look at this thread:http://osgeo-org.1560.x6.nabble.com/Question-On-quot-BallPark-Transform-quot-td5431149.html#none
-Thayer
===================================================Message: 1
Date: Sat, 2 May 2020 13:45:44 +0930
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] FW: Help with georeferencing AGD66 Topo map
Message-ID: <5E8A564B04F6241C at smtp.telstra.com> (added by
postmaster at smtp.telstra.com)
Content-Type: text/plain; charset="utf-8"
Hi- I am seeking help with this.
I have been trying without success for a while to georeference a topo map that is in Australian Geodetic Datum 1966, using both EPSG: 20250 and EPSG :4202. I think 20250 is preferred.
I have been successful with similar maps that use WGS 84, but can’t work this one out.
I am figuring this out /doing this in my spare time for ametuer use in Avenza by the local bushwalking club.
Attached are screen shots
• Error message is about a Ballpark transformation. Also says : Used a ballpark transform EPSG: 4202 to EPSG: 3426
• Project Properties
• Transformation settings
• GCP table -as with previous success maps I am using the UTM Grid for coordinates: Example 501000 / 8258000
• Map Info
Map details are Beasley Knob 4766 3 which I downloaded here:
GeoScience Aust 1:50 Maps
So any guidance appreciated- I image it’s a simple mistake.
Kind regards
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200502/76339e69/attachment.html>
